So I finally found another L275 which was missing some parts (injector pump, injectors, lines, hydraulic pump, intake manifold, etc...) and I brought it home as a parts machine for mine which threw part of rod #1 through the block before I bought it. Supposedly the engine on this donor tractor had "been rebuilt" shortly before the parts were "stolen" off of it, but after swapping the engine over to my tractor and finally getting it to fire up and seeing all the smoke it's blowing, my suspicion is that someone sold some parts off of it to recoup some money from a tractor that needed an engine rebuild. When we had the head off we noticed that the cylinder sleeves were not scored but a couple of them had been exposed to some moisture at some point, so that's surely why it's smoking. They feel pretty smooth, so I'm hoping we can lightly hone the sleeves to clean them up, and replace the rings.
After FINALLY getting the engine to start (it's tough to get going), it has a noticeable knock from cylinder #1 until it runs for 5-7 seconds, then it smooths out. While the starter is cranking, the engine "pauses" or at least slows down on every 3rd cylinder stroke with a very audible "clack" sound. We've not yet had the chance to pull the oil pan and check things out in the bottom end, but is this likely rod bearings or a head clearance issue?
Also, after the engine started I noticed some fuel seepage at the base of the fuel injector on cylinder #1, and to a lesser extent, cylinder #2 where they thread into the head. Is there supposed to be a copper washer to seal that area or not?
Pretty depressed. Any suggestions would be appreciated.
