L275 clutch pedal stopper adjustment
timsch
'49 8N, L275DT
Jun 11, 2018
119
23
Houston, TX
My L275DT has a clutch stopper that has an adjustable bolt to limit clutch pedal travel. How do I check it for proper adjustment? Right now with it down, I can change gears, but there is a little resistance to it. I'd like to make it as easy to shift as possible without having the stopper adjusted too far where I'm burning the clutch for the PTO. I don't see anything about this in the manuals.
Thanks.
timsch
'49 8N, L275DT
Jun 11, 2018
119
23
Houston, TX
I haven't checked, but adjustment procedure should be in the manual.
https://www.manualslib.com/manual/1101745/Kubota-L185.html#product-L275
When you download it, it doesn't have the mirror effect
I had previously purchased the shop manual. I looked through the section on adjusting the clutch before posting and didn't see that covered. It covered adjusting the clutch itself as well as the pedal free play and the starter safety switch, but not the pedal stopper from what I saw.
1,774
Take a picture of what you’re looking at.
I don’t recall any stops on the clutch pedal on my similar L185 but really have not studied it.
6,392
The L305 has a flip down lever held in place by a spring to allow the clutch peddle to extend down (or up) to activate the second stage for PTO operated devices.
