L275 Auxiliary Hydraulics
thewarrior1012
Kubota L275DT
Jun 6, 2015
Brighton, MI
I have an L275 that I want to add some auxiliary hydraulic ports to. I see the small block under the seat with two pipe plugs near the relief valve, and the manual shows it able to have a flange type power beyond circuit added there.
So, how do I do that? Is that current block just a bypass? Do I need a different block at that location? I don't want to cut into the existing hydraulic lines, and this seems like it was made for what I want.
I was thinking of adding three valves; a top and tilt, and a third function for other stuff to plug in later. I have a L1730 FEL with the Webster pump off the crank on the front. Is it better to tap into that?
Sent from my SM-N900V using Tapatalk
thewarrior1012
Kubota L275DT
Jun 6, 2015
Brighton, MI
Ok. So doing some digging, I see the stock block is just connecting the two ports. It looks as if I could machine a block that has a pressure port and a return port, and plumb them to a valve set with open centers.
Is this correct?
coachgeo
Nov 16, 2012
2,459
37
Southern OH
Is this correct?
think "block" is your keyword. Search using keywords hydraulic and block and you should find several threads on this topic
