L2650 won't turn off with key
kubotaworks
1994 L2650
Mar 2, 2009
Northeast Washington State
Help! I recently purchased a nice L2650 from a local dealer, and now the last few times, won't turn off with the key. I have to pull the engine shut off lever.....I replaced the key shut-off fuse, it's still doing it. Any ideas? :confused:
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,187
170
Hardisty, Alberta
Either the shutoff timer or the solinoid. Jumper power to the solinoid to see if it works, if it does the problem will be the timer or the connections at it. The timer is above the engine in front of the fuel tank, it has a four wire connector.
Ed
