L2501 turning over but won't start
1tmcort
Silver creek
Hi new to the forum. I bought a new L2501 in August of 2017. It currently has 65 hours. I recently had my tractor in the shop because it had a damaged fender due to rolling over a sapling. It has always run great and did when I took it in. After I got it back it seemed fine but all I did was load it on a trailer bring it home and unload it park it in the shop. Now after a month of sitting I rolled it out for use. It started running rough especially at higher rpms. Around 1500+. I had a full tank of diesel in it and my reading about its condition also it was coughing up white smoke. I really believe this is a fuel issue so I took of the fuel filter and sediment bowl which did show some small amount darkness in the bottom of the bowl. Cleaned it up and put it back together. It ran better at idle but when I brought the rpms up it started sputtering again so I dumped all the diesel out of it and put it all back together. Now it wont start at all. I've bleed it with the bleed valve as per the service manual. My question is could it have a really large air pocket in it keeping it from starting or maybe God forbid a bad injector pump? I'm not sure where to go from here. Any help would be appreciated. Thanks
Roadworthy
L2501 HST
Aug 17, 2019
1,647
530
Benton City, WA
Does fuel flow freely from the tank? You could have a build up of crud or fungus preventing proper fuel flow. This could prevent proper bleeding and would certainly kill the engine for lack of fuel.
11,493
Recheck fuel tank and filter output flow.
Pull the input line to the injection pump and crank it, you should get pulsed fuel flow.
It's not the injection pump!
But you might have to crack the lines at the injectors and get the air out of there in order for it to bleed completely and start.
And treat the system with a biocide/ algaecide.
quicktractor
Kubota L2501
Jul 27, 2017
22
Flagstaff
Any thought on this method for "bleeding" a diesel???
Note: skip ahead to about 1:30 in the video to see the trick.
https://www.youtube.com/watch?v=f5qfEayHx8c
sheepfarmer
Nov 14, 2014
4,438
678
MidMichigan
My opinion, it is not a good idea. There are a bunch of different fuel delivery systems among the Kubota tractors. Since you have a new tractor, follow the directions in the owners manual. After you follow Wolfmans advice about getting rid of junk in the tank and filters.
