L2501 - Hydraulic powered skid steer quick attach
Repair
2017 L2501 - 2020 L2501
Apr 17, 2017
152
24
Lebanon, TN
I tried to find a kit to buy, I even went to Kubota but I couldn't find a kit to have a Hydraulic powered skid steer quick attach for my L2501 so I'm building one.
It works, still need to lube and make some adjustments.
Nicfin36
Jun 19, 2019
1,018
472
Decatur, AL
Very interesting. I look forward to seeing it all put together.
Nicfin36
Jun 19, 2019
1,018
472
Decatur, AL
Heck yeah! That's awesome. Very cool modification.
Repair
Apr 17, 2017
152
24
Lebanon, TN
Thanks!
It needs some fine tuning and it's time to get the second front hydraulics system on it.
I plan to cut new arms that are up when open and level when down with a protective cover.
I have the Kubota front hydraulics kit but I'm replacing the control valve with one from from Summit Hydraulics that has 2 front hydraulic feeds/solenoids.
10,744
You also need a buffer / flow restrictor on that small of a cylinder.
It will react better for you.
Repair
Apr 17, 2017
152
24
Lebanon, TN
I agree, this is the prototype so I expected to have to tweak things.
I'm running it off the feed for my grapple and hydraulic auger but I plan to run a restrictor in the cylinder once I get the dedicated hydraulic system on and I plan to get a ram that has less travel
tractorX
KUBOTA L2501 DT 5' BOX BLADE 42" FORKS PIRANHA TB 5' BUSH HOG 6' GRADER
Sep 27, 2013
82
Rock Spring GA.
thats cool... but i'm more impressed with that 396 black SS. absolutely gorgeous!
RogerFisher
Sounds like a great plan.I like your ideas!
drwill
M5030SU, M7060hdc12, RTV X900, ZR224-48
Feb 16, 2021
This is exactly what I have been looking to do. This valve has a plug in the T port so do you remove this plug and connect here for power beyond. Thanks in advance for any help.
drwill
Feb 16, 2021
How do you plan on restricting flow to the cylinder?
Repair
Apr 17, 2017
152
24
Lebanon, TN
I have the Kubota third function kit but I bought parts to have 2 front hydraulic systems.
I can post pictures of what I have once I get it put on.
Joe Messmer
ZT21,B3350,LA 534,BT77
Jun 1, 2017
15
Edgewood Ky
I really like what you have come up with and want to do it to my B-3350 . Can you advise what the dimensions are on the cylinder and where you got it and the orifice's ?
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,899
2,314
Western MT
Sounds cool. I don’t switch many times in a day, so it would be basically almost unused for me.
Crash277
BX23S
Jan 17, 2021
844
623
That’s awesome!! I wonder if it would be easy enough to just use a diverter for that function? Since you wouldn’t have to worry about using curl at the same time.
Repair
Apr 17, 2017
152
24
Lebanon, TN
I don't see why not and it would save a lot of money, if you do it be sure to post it!
