I am not sure if this is actually a problem or not. When I have the l2501 at max revs ...2400ish....I notice it tends to stumble and bog down under load...like it's running on 2 cyl and starved for fuel...I am aware the sweet spot is around 2200 but is this normal? I understand the engine was defined to meet emissions so perhaps that's the issue as well...or maybe my throttle should not allow it past 2300rpm? Appreciate your thoughts. At 2209 rpm and lower, it runs lime a champ. I am interested in the mod for boosting the most from the engine, n but it's still under warranty
Cheers. Scott
Cheers. Scott
