L2500D PTO lever VERY hard to move
FloridaAl
L2500DT, King Kutter 5' bush hog, Howse 4' disc, back blade, plow, boom pole.
May 15, 2019
15
Jacksonville, FL
The lever that engages the PTO shaft is really hard to move. I can't move it by simply pulling or pushing while sitting. I have to sort of hit it with the heel of my hand. Yes, I do have the clutch fully depressed when engaging/disengaging.
I don't believe this has cables but I could be in error. The diagram I have looks like an almost direct gear engagement.
Once engaged, the PTO works fine. Is it possible the PTO shift lever needs lube?
Any suggestions, tips, or ideas welcome.
Thanks. Florida Al
8,770
Where the lever goes into the case might have rusted, try some PB blaster.
