Hi my Kubota is a 1997 3 cylinder diesel , recently the engine became flooded with hydraulic fluid , so i drained all fluids filters , pulled hydraulic pump removed snap ring replaced output seal and all associated orings , re installed filled fluids started tractor and after about 4 minutes filled engine again with trans hydraulic fluid ,, any ideas other than replacing with new hydraulic pump ( because I have a new one on way ) could it be coming from another area or could something like pressure relief be bad ? thanks 3tike new to forum
