L2500 headlight conversion
kayco53
2500dt
Mar 22, 2020
langley bc
Has anybody converted the headlight bulbs on L2500. They are a real weird bulb. Would like the extra power to run other lights. Thanks
wokndadog
Kubota L185, L2500+LB400 loader & X350 chipper, AC 912H, JD 112 RF and X740
May 28, 2015
Central PA
kayco53,
Did you have any luck finding an conversion bulb?
You and I should probably team up, otherwise it looks like we are on our own...
L2500 seems to be the redheaded stepchild of Kubota...
wokndadog
May 28, 2015
Central PA
Guess what?
I was searching for some other L2500 parts on ebay and found these LED's which are supposed to be a direct fit (NO modification needed).... They also have LED's to fit the L175 and L185 as well as several others.
Butch
Sep 10, 2009
696
202
Rising Sun, MD
Check out www.superbrightleds.com. They can assist in your conversion and they are reasonable too. That is where I got mine.
Ironstein
L2500,brushog, box scraper, rock rake
Aug 15, 2018
Gig Harbor WA
kayco53,
Hey guys, any luck, I’m looking for headlight assembly for my 98 L2500,
Also my front end sheet metal is a bit bashed in, not finding anything?
