L245DT w/1200 Loader
akcdualch
L245DT w/1200 FEL & BH750
Mar 17, 2010
12
Petaluma, CA USA
www.brytestar.com
Hi everyone,
I'm new to the forum and Orange Tractors! Just purchased a L245DT w/1200 loader and am in the process of servicing everything. I have the Operator's manual for both the tractor and loader but my loader has a pump attached to the front of the tractor and a Hydraulic tank and filter mounted on the loader. The loader manual does not show these parts. I would like to service the loader and would appreceiate any help, information or advice in locating a part # for the filter and procedure for changing fluid plus amount to put in the tank.
Thanks in advance!
akcdualch
Mar 17, 2010
12
Petaluma, CA USA
www.brytestar.com
Thanks for the reply. Napa has two common hydraulic spin-on filters, one of which should fit. One is a 10 micron, other is 30 micron filter. I guess I have to disconnect a line from the tank to drain it. Looks like there is an air breather on top where I can put new UDT in. How much is another question!!
Theekillerbee
273
Pleasant View UT, USA
If it is fully contained the loader, just eyeball with a flashlight down the filler. Keep it up just under 1/2 way up the loader post. Run your machine and if everything functions well, and your fluid level is good, you should be golden. Remember it is purely a reservoir for fluid, and unlike an engine or tranny, precise oil fill is not required.
