L235 no fwd
claya1
Kubota
Sep 24, 2021
49
sacramento
Fwd failed today. It shifts in/out of 4wd no issue. What specifics do I look at first? 4wd drive shaft, rear transfer case, etc...
How do I determine if the 4wd drive shaft is spinning? If I raise the front wheels with the loader they spin freely in both 2wd & 4wd.
7,396
Access openings for propeller shaft on underside of tunnel?
rbargeron
Jul 6, 2015
1,185
262
western ma
The rear gears and transfer case rarely fail. The most common problem in the front drive system is the propeller shaft couplings. The internal splines rust and eventually wear enough to stop driving.
To inspect them, unbolt and slide the telescoping tube together, drive out the rear coupling's roll pin, and slide the coupling enough to take the shaft down and out.
Another possibility is worn out gears in the front differential.
claya1
Kubota
Sep 24, 2021
49
sacramento
The front coupling roll pin was MISSING. Question is: Where did it go?
Previous owner rebuilt the transmission, and replaced the clutch. Is it possible he did not put the roll pin back, and the coupling has just been free sliding? The 4wd was definitely working for a few months after I got it.
The front coupling is pretty worn, compared to the rear coupling.
It looks like I may have to drop the FEL brace to replace the propellor shaft couplings, correct? Or is there enough clearance to slide the shaft back and remove the front coupling?
11,354
Should be able to slide the front or rear coupling back enough to remove the propeller shaft.
rbargeron
Jul 6, 2015
1,185
262
western ma
On the models I've done, the rear coupling slides forward, allowing the end of the shaft to drop down a bit and come out toward the rear. Mine have all had Kubota loaders which didn't block that. Maybe others do? Dick B
claya1
Kubota
Sep 24, 2021
49
sacramento
What part number is listed for #5 coupling? This is the only correct diagram I have seen for the L235. All the others do not show/have the roll pin.
rbargeron
Jul 6, 2015
1,185
262
western ma
The current part number is listed as H3520-44520.
Mike66
9
Castor,alberta,canada
The shaft that has number 3 above it. Is that a pain to find and change? Coupling is stripped aswell as shaft. Any ideas on what to do? Thanks
