I just picked up a L2250DT tractor, and it had a real bad, I thought was, fuel knock. I put new injectors in it and that didn't change a bit, so I decided to pull the head off and found an issue with the front piston/cylinder. My question is can I get the oil pan off with the engine still in the tractor? To me it looks like if I can get the front driveline out of the way I could pull the pan off and knock that piston out of there, but not sure if this is possible. Thanks for the help.
Randy
Randy
