L2250 4wd
Apologies if terminology not accurate. Looked for a previous post on this topic but didn't find anything.
In changing the Front Axle Case 80w-90, the removed fluid was quite different from one of the drain plugs than it was from the other two plugs.
Drained fluid from the "front axle case" drain plug looked like new.
Drained fluid from the two "bevel gear cases" at the wheels looked like would expect used gear oil to look like.
Looking to learn if this big difference in the way the drained oil looked is typical --- or if it may indicate something that needs looked into.
Forgot to record the hours for the last fluid change, but the interval was likely beyond the recommended 400 hours.
Thanks.
Thanks.
