L2250 front to rear weight ratio
Billy13
L2250, B8200
Feb 2, 2011
31
Choctaw, OK & Boardcamp, AR
I am going to take my L2250 for a 5 hour drive tomorrow and I was wondering if anyone knew the axle weights for this tractor. I know it isn't absolutely critical I put it on the trailer in just the exact spot, but I would like to be close.
gktilton
79 B7100 w/ FEL, Deere 261 Finish Mwr, Woods M4 Bush Hg, Potato Plow, Cultivator
May 5, 2010
230
Hooksett, NH
I don't know the answer but others will. They will need to know other things though.
Any added weight, loaded tires, front loader, cab. They will all effect balance.
Kubota Newbie
M4500, New Idea Cut-Ditioner, JD 14T Baler, IH "Plow Chief" plows, Oliver Rake
Dec 28, 2010
480
39
Mount Vernon, Ohio
It's more important how you position it on the trailer than what the front/rear weight split is on the tractor. For good towing you need to have a load on the trailer tongue (otherwise it will sway and braking performance and handling of your truck will suffer). Pull the tractor forward on the trailer 'till the bumper sags a little below the normal unloaded height but not so much that you use up more than about 1/3 of your travel in the suspension. RC
RDR
M5400,B6100E,K008,L175,TG1860Diesel,JD355D,3)Leyland 154D's,YM2000,IH1466
Oct 13, 2009
147
Danevang, Tx.
ALWAYS be tongue heavy. If you can't get enough weight on the tongue to keep it from swaying, you don't have enough truck. I have a 1993 Chevy one ton, flat bed with dual wheels that I don't use that often. The plates and insurance aren't that much. I can't stand to pull a trailer without the dual wheels on the truck. It comes in handy for picking up tractors or whatever else I might acquire. With scrap prices up it has made a little money.
