L185 no start
carroll
Kubota L185
Aug 29, 2012
21
mansfield Georgia
My L185 will not start. Took the starter off and had it rebuilt put back on turned key lights up but went to turn starter switch nothing. Any help would be appreciate and thank you
Tooljunkie
May 13, 2014
4,150
34
Ok. So lets eliminate things one by one,
Battery, assuming its good and cables are CLEAN on BOTH ends including where it bolts to frame.
Small wire that connects to starter is snug, not overtightened and broken inside.
This wire typically passes through clutch switch before connecting to starter.
By jumping from battery cable connection to this small terminal (tractor in neutral) engine should turn over.
If the first things mentioned are good starter should crank.
If it cranks, then we can assume the clutch switch or ignition switch and related wiring is faulty.
2,601
Be sure tractor is in neutral before testing per above method
