L01 Rear Remote Mounting Panel
7,390
Pretty cramped for me sitting in that backhoe seat even with nothing on the inside of the ROPs currently. Either my elbows or legs would likely be hitting something if inside the ROPs.
Yes. I spent a little time looking at the possibilities and I think the backhoe is simply going to be an "incompatible configuration".
RCinNC
L2650dt, L2800hst
Sep 10, 2024
North Carolna
When I purchased my L3901 this summer I was aghast at the cost of factory rear remotes and disappointed in the cut-rate outlet kits that came with them so I set out to build a better mouse trap. Here is what I have come up with so far.
The panel is a simple bolt on installation using the existing fasteners for the tool box and top link holder. It is cut and bent from 3/16" steel plate and accepts standard ISO one hand push-pull panel mount couplers. Hinged covers or rubber plugs are available for dust protection. Personally I plan on adding 3 rear remote valves to my tractor so in these pictures the right side is populated with couplers for them. I also have a 3pt log splitter so I wanted a power beyond outlet for it. The left set of outlets are the power beyond hookup - red is pump out and blue is pump return. The knob in the rmiddle is a 3 way selector valve that turns the power beyond outlets on and off and eliminates the need for looping hoses together. To use the splitter I simply get off the tractor, plug the hoses into the power beyond outlets, and pull the knob out to start flow. When I am done with the splitter I push the knob in to shut off flow and then disconnect the hoses. Unused positions get blanking plugs.
In the near future I intend to offer these things for sale along with a low cost alternative to the OEM rear remote valves (still under development). It will be available as a full kit or individual components. For now I would like to hear folks comments on the panel design and any expressions of interest in adding something like this to your L2501/L3301/L3901. And just to set the record straight I am comfortably retired and don't need to supplement my income. I just like to tinker and need something to keep me out of the bars and brothels :rolleyes: Consequently all of these things will be priced WAY below Kubota and lower than quite a few third party sellers.
I'm very interested in your panel. it looks like it would work well on my L2800. Do you have them available yet?
Rod
7,390
Rod
I had some but may have tossed them when I decided to go a different route. I will check.
I think this is much nicer. The outlets are modular and can be stacked any place across the rear. You can have multiple stacks to match your needs. The sleeveless couplers are a little pricey but superior to the two way sleeve ones used in the panel mount.
7,390
Rod
Well I did not scrap the extra panels so I have 7 or maybe 8 of them. Anybody that wants one (or more) can have it/them for the cost of shipping.
They are custom cut and bent to bolt to the crossbar on the back of an L2501, L3301, or L3901. Probably would not take a lot to make them fit something else. The panel accepts 1/2" body couplers with 2 way sleeves. Retaining rings are used to secure the sleeves to the panel. One hand push/pull coupler operation with breakaway protection.
PM me if you want one.
6869704x4
L45TLB, 49 8N, 57 641, RTV-X1120D, Z422, CanAm Outlander 650
Jun 29, 2011
400
542
SE, NM
How do you like those toilet seat dust covers?
6869704x4
Jun 29, 2011
400
542
SE, NM
I love them and they are cheaper than the plugs.
I did a search and only came up with them in the UK. Faster brand. You got a source by chance? Also, what goes on the male end? Standard cap?
7,390
