My friends said hooking this up was a real pain…. I did not believe it would be. In a recent post, I questioned whether my FEL was out of whack. Some said it was tire pressure. Anyway, with the subframe on the floor and the drawbar in place, I lifted the front end only one front pin would go in and one rear pin diagonally. I had to jack the subframe up 1/4-1/2” so the front would go…..then i had to jack the frame of the tractor at the pin and coax it home. PITA.
THEN, to remove the draw bar i had to jack frame up just slightly to release the PINCH and it came out just like that.
Is this normal?
Is this normal?
