OK, I have my L 225 split between the trans and the flywheel housing. I've replaced the trashed reverse gear and will be replacing the clutch disk. A few questions have arisen;
The end of the main shaft does not go into the pilot bushing. It has a finished appearance but will not reach and the diameter is too large to fit in the pilot bushing in the flywheel (see pic, hopefully). Is this normal?? I have never seen a transmission main shaft that ends after the clutch disk. There is no support at the forward end of the shaft. This doesn't seem right to me but the shaft doesn't look broken, on the contrary, it looks finished off properly. Has anybody come across this type of thing before? Vic?
Also, the pressure plate and flywheel showed a few small hot spots but not enough to replace them. Whats the best thing to use to clean up those surfaces??
One more, does this model have a screen in the trans that needs to be cleaned?
Hope the pic posts,
Thanks,
Tom
Hope the pic posts,
Thanks,
Tom
