KX161-3 Temperature gauge issue
Capstick
KX161-3
Jan 10, 2019
PRESTON, United Kingdom
When running, the temperature gauge is running hot (off the scale) even though the engine isn’t and the fuel gauge is reading wrong too. We have fitted a new sensor and also had the dashboard checked and they have said the dashboard is not faulty however the issue remains. Please can anybody offer advice?
2,744
Typically when a "gauge" reads to the extreme......the system has been grounded.
In a fuel gauge (empty) - the internal electrical resistance is high, thus the gauge read low or not much movement.
When the tank is complete full - the gauge movement is via the sensor connector to a low resistance thus current flows making the meter move to the extreme reading.
A quick way to see if a gauge is working, is to bypass the variable resistance, and ground the meter - should peg "full" or "hot"
I would check the "grounding" cable on those - since both are effected - I would trace all the way back to battery.;)
