I am having issues with a Kubota KX121-3 S Series Mini-Ex. (2200 hours) the machine was parked for 3 weeks and not started but was running great when I last shut it down. The next time it was started it started perfect and idled fine while it was warming up. Then as I started to drive it started bogging down and sounded like the engine was about o die. I let off the forward controls and the engine smoothed back out and seemed okay. I checked the fuel gauge and it was at 3/4 tank. I was starting down a hill so thought it may have been about out of fuel which is what it sounded like. I managed to baby it down off the hill to a lower area to do some work and it seemed to get better as the machine continued to warm up. However when I when to use the bucket it would almost die again. Actually any hydraulic commands would cause this including forward or reverse. It did this three or four more times and then it cleared up and ran perfect the rest of the time I used it that day Approximately 4 to 5 hours work time. The next day I went to use it again and this time it would not clear up and run no matter how long I let it warm up. I finally shut it down.
A couple days of sitting once again due to rain, I purchased a new OEM fuel filter from Kubota. Also purchased diesel fuel additive that was supposed to remove any water, slime or algae from tank and also was supposed to clean injectors etc. ($20 + per bottle.) I added the prescribed amount of additive to the fuel tank. I then removed the sediment bowl and cleaned it out. There was no water in the bowl at all, but had a tiny amount of what looked like dirt possibly in bottom of it. I then removed the air filter and inspected the (outer air filter) It had some dust in it that I was able to tap the filter and it seemed to knock it out and I stopped when no more dust fell out then replaced it and reassembled the filter canister.
I then tried to start the machine and the sputtering and bogging down started immediately. I decided to let it run for a longer period of time to let the fuel additive and cleaner have time to work through the fuel system but it never cleared up. The machine with no load and at idle or even with the throttle up to mid-way it made no difference. It will run perfect then suddenly start to miss, sputter, shake and then almost die, puffs of black/white smoke come from exhaust, then clear up run perfect. After a few seconds or at times even 2-3 minutes o running perfect it will again go through the sputter event again. Doing this over and over no matter if engine has warmed or not. So....What else can I possibly check and also if it's an injector pump is there a way for me to check this to be sure without special tools etc. before purchasing one.
Additional Info:
I can hear the fuel pump and it sounds consistent as far as the sound it makes it doesn't appear to slow down or speed up. Although I haven't taken any lines off to ensure this flow is steady. I also haven't blead the system simply because when I researched how to change the fuel filter it was only recommended that the fuel shut off to the fuel sediment bowl (a clear see through bowl with a red ring that floats when water is present) then to wipe down the area around the filter prior to removing the old filter, then to fill the new filter with clean fuel and reinstall filter. Next turn the sediment bowl shut off back on and to turn key switch on for a few seconds before trying to start the engine. This was the prescribed way I found to "Prime" the system after fuel filter change and sediment bowl clean out. I cannot find a procedure online for actually bleeding the fuel system.
I have also pulled the parts schematic for the fuel system for this machine up online and according to Kubota's drawings that I found the prints have print item numbers for replacement purchases etc. There is a total of two filters. (not counting the sediment bowl) One was actually a strainer that is at the fuel tank entry. I would actually call this a fuel strainer rather than a filter but okay whatever....Potato, potatah. The other is the actual metal screw on filter. It is like the oil filter but smaller and silver with Japanese writing on it. If there is another filter somewhere in this fuel system Kubota failed to show this in their documentation.
Any help figuring out what to purchase or do to repair is greatly appreciated! Time is of the essence as I'm getting further and further behind each day this sits.
Additional Info:
