Kubtoa RTV X1100C oil leak
RTV
RTV-X1100C
Mar 9, 2021
I have a new Kubota RTV X1100C and it is leaking oil out the back after operation, but not at rest. The unit is under warranty, but they cant figure it out. I am not sure about if the leak is related to inclines but I know it is not leaking at idle, only after operation. Anyone know of an issue with the transmission 'burping'?
5,506
2,213
yes I had one that did that when I worked at dealer.
I was advised that the level in the transmission should be at the top of the mark on the dip stick at operating temperature only, when cold it should be at the low line. Same for the tank under the seat.
After adjusting the oil levels, and verifying that it did not have the incorrect fluid, to my knowledge it never showed back up.
Also be aware that the oil cooler needs to be kept clean to avoid excessive oil temp, which will contribute to "burping".
RTV
RTV-X1100C
Mar 9, 2021
Thank you
