kubota zd331
clarkcc
Greenville TX
I am new this site and have found it helpful today. I have a Kubota zd331 that while I am operation it dies. I have taken it to 2 Kubota dealers and both said they fix it then when I get it back it does the same thing. At the dealership they cleaned both tanks, and replaced the seat switch. Neither of these things has helped.
It dies any give time, not necessarily when its hot or cold.
Could it be the fuel pump?
Thanks in a advance
8,705
When it dies what happens exactly?
Does it slowly die, or just shut off suddenly?
If slow, any smoke?
If fast, is it like when you turn off the key?
Does it restart easily right away, or do you have to wait or have to crank excessively?
clarkcc
Greenville TX
Dies quickly like turning the key. Usually it does not start right back up but it will eventually and runs just fine. until it dies again.
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
The Wolf has started the process - if it dies quickly then it's likely an electrical issue relating to the fuel cut solenoid. So a loose wire somewhere, faulty key switch, a seat switch or relay etc.
