You might want to do the the low voltage relay mod. I've done both my BX22 and ZD21. Get the power for 30 from the battery connection on the starter, 85 to any clean metal surface, 86 will be the white with black stripe that is currently on the starter solenoid, and 87 will go to the solenoid where you pulled the white with black stripe from. The low voltage on the black/white wire will be enough to fire the new relay and the new relay will give the starter solenoid 12 volts. Works like a charm.
