Kubota won’t start
Reginaldjamesberry
Mini digger
Sep 7, 2023
9
Oxfordshire
Hi
I have a Kubota U10-3 mini digger, with a really odd problem, it turns over fine it seems to be trying to start but unless I push or pull one of the drive hydraulic levers it will not run !
It simply turns over & won’t start, push one of the levers whilst turning it over and starts absolutely fine.
any ideas ?
I have replaced
Head gasket
Injectors
Glow plugs
Filters
Solenoid
but the fault remains exactly the same
Reg Berry
Oxfordshire
2,898
Reg,
I am somewhat taken back at the length of parts that you have replaced!
Not knowing the specifics of your machine - what you are describing is a safety switch that is causing your problems. I would imagine there are switches attached to each of the "levers" and one is not closed or open depending on it's specific design.
Pawnee
L2501
Jul 1, 2021
371
336
Ontario Canada
The interlock switches usually prevent turnover.
His is cranking fine but doesn't start.
2,898
True - but the fact he wiggles something and it does start tells me something is amiss electrical wise.
Reginaldjamesberry
Mini digger
Sep 7, 2023
9
Oxfordshire
massive thanks for your thoughts.
I don't think there is any safety switch, mainly because I can’t think what it would control ? As far as I can see the only thing that stops the engine is the solenoid?
lynnmor
B2601-1
May 3, 2021
1,687
1,475
Red Lion
Now find out where the fault is in the solenoid circuit.
2,499
What does the lever control? I think it is a hydraulic valve lever and moving the lever unloads the hydraulic pump and the engine. That allows the engine to run since the hydraulic fluid can flow more freely?
Would you be able to disconnect the hydraulic system from the engine easily? I doubt that it would be very easily done. But perhaps you can find a way to get the hydraulic pump to have no flow restriction and decide if that is the problem?
Reginaldjamesberry
Mini digger
Sep 7, 2023
9
Oxfordshire
