I have a kubota l35. As I lift the front tires off the ground with the front end loader I can grab the front tire and shake it back and forth from side to side. There is a lot of play in the front linkage. After looking at it I discover that the looseness is in the center under the oil pan where both tie rods meet. There is a thing that I'd call a drag link on a car up there that has a grease fitting on it and the bushing is very loose.
Can I replace the bushing or should I buy the whole arm? How does the thing come out of there? It doesn't seem like there is any room to remove it. Thanks
