P Peter Kelos New member Equipment B2150, F3060, GL6000 Jun 23, 2025 2 0 1 Canada Monday at 10:06 AM #1 I have a spiral bevel gear that I was given years ago and it is apparently for a Kubota. There are no indentification marks. Does anyone know what it fits?
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 33,240 8,606 113 Sandpoint, ID Monday at 6:39 PM #2 Sadly without the mating gear it's pretty much worthless as they are a matched set. I don't know of anyway possible to find out what that fits.
P Peter Kelos New member Equipment B2150, F3060, GL6000 Jun 23, 2025 2 0 1 Canada Tuesday at 5:50 AM #3 North Idaho Wolfman said: Sadly without the mating gear it's pretty much worthless as they are a matched set. I don't know of anyway possible to find out what that fits. Click to expand... Sadly I know you are right. I thought if I could identify where it goes, someone might want to take a chance and use the pinion. Thanks for your help.
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 33,240 8,606 113 Sandpoint, ID Tuesday at 8:44 AM #4 The dual tooth gear would be worth it to someone. Count the teeth on each end and I might be able to find its use.
