Kubota Rims
Paul
B7000 DT
May 27, 2009
Winnipeg, Manitoba, Canada
Does anybody know where I can get front rims to fit Kubota B7000 DT or if there is a part # from a North American dealer of Kubota that will fit?
Much Appreaciated!!
uncle jed
1990 f2100
Oct 25, 2009
25
hillsboro,tx. 76645
Mikefpa, what size wheels? on the F2100 the ones on the steering axle are the same size as on golf carts {8"} with 4" bolt spacing the wheels on the front of the F2100 are the same size as most five lug garden tractors 12" with 4.5" bolt spacing
tiredguy
B3030 HSTC,B2781 51" front mounted snowblower,60" MMM
Jan 21, 2010
301
northern lower Michigan
I'm with Vic on this subject, unless you find a used set or are very well connected with a mfg that can make the proper centers you're pretty wel SOL.
And his way most likely the least expensive way to go too.
Al
PS: most Kubota wheels of the same size have totally different bolt patterns and the interchange between models almost zero.
Rustbucket
B8200HSTD, rotavator, transport box, trailers, old Land Rover
Jun 2, 2011
17
Ireland
Can anybody advise if 3103-2003 10-24 wheels have the same stud pattern as 67800-50120 8.3-24 ? What about the web offset?
I may have a lead on a pair of these NOS. The closest dealer wants the equivalent of almost US$500 each for 67800-50120.
Thanks for any help!
Rustbucket
Jun 2, 2011
17
Ireland
Cancel that. I've just seen a picture, and they're 8 stud wheels.
Looks as though the advice given by tiredguy is good!!
Rustbucket
Jun 2, 2011
17
Ireland
Gemplers carries a selection of wheels which may fit your particular application.
Thank you for that tip - I've sent them an email enquiry, but I suspect that the shipping costs may be prohibitive. I'm also putting out feelers with the Chinese compact tractor dealers - they might have spare wheels of the right dimensions.
