Hello all, hoping for some insight ona problem I am experiencing.
Recently installed a LA852 Loader onto my Mx5000 tractor and cannot get the Front End Loader to operate correctly.
Loader control valve is brand new and seems to be doing everything correctly but it seems as if I have a pressure situation. If I start the tractor and operate the FEL I am able to dump/curl the bucket as well as raise it. However if I go to lower the loader it does not lower until I put it into the Float function and then it drops quick/erratically from the weight.
If I move my 3point position lever to just past the highest level (to where the pump starts to whine ) then I get my lowering function of my loader to work correctly but no other function will work while in this state.
what could this be ? Do I have a bad relief valve?
Thanks in advance for your help!
