Kubota M7060 3 Point Hitch Issues
ryegrass26
United States
I'm experiencing a ratcheting effect when trying to make small adjustments while operating my 3 point hitch. I can't effectively use my tractor with a blade because of this. Hopefully someone can possibly help me resolve this issue.
Thanks
ryegrass26
United States
I have tried it in every position and nothing changes. The dealer recognized the problem and took it in and changed all kinds of parts but it does the exact sea thing. Now he's telling me that's just the way they operate and theres nothing else he can do to repair it. This isn't my first Kubota tractor that I've owned and I've never experienced anything like this. It only has 6 hours on it and I'm not going to use it like this in case I have to file a claim against them. I was hoping someone knew of something I could do to minimize it. After doing some research it appears that Kubota has similar issues in other models. Do you have this model tractor, does it do this?
GWD
M7040, L48 TLB, BX2200
Jan 8, 2010
792
19
Northern California
I have the M7040 and, no, it does not have the issues you describe.
Time to get in touch with Kubota Corporate.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,298
184
Coyote Flats,Texas
I'm with GWD as I have a M7040 with no 3 pt hitch problems. Which hole in tractor center link attaching bracket do you have center link attached?? I'd suggest top hole if not already attached there.
jcummins
Kubota M7040, F3680, JD Gator 855D
Oct 19, 2013
45
Creal Springs, IL
If they can't fix it. ...I'd make them buy ot back. It is not suppose to work that way.
Sent from my SCH-I545 using Tapatalk
ryegrass26
United States
Yes initially they had the hydraulic top link set in the bottom hole and claimed that was causing the issue. They had put me a 3" cylinder for the top link and it wouldn't fit in the top so they put a smaller diameter cylinder and moved to the top position and still does the same thing.
Guys I'm not sure if I explained myself correctly but I can have this tractor in park and slightly raise the 3 point hitch lever and it will shake or chatter not sure what to call it all the way up until it reaches the desired position. When lowering it goes down fairly smooth. When I'm dragging the box blade and it starts cutting and I raise on it a little it starts that jerking it becomes impossible to carry a nice grade. I still have my 2010 L3940 HST which doesn't have the draft control system and appears to be much lighter duty but the 3 point on it is just as smooth as you could expect. I wonder if this M - Series tractor might have been designed with this draft control system to be primarily used to pull plows and other larger attachments that don't require a steady 3 point hitch? Although I didn't order a plow with it, the box blade I'm trying to use was ordered with the tractor.
GWD
Jan 8, 2010
792
19
Northern California
Nope, the hydraulic system is fouled up. It likely has something to do with a pump problem.
The reason it is smooth going down is that the hydraulic system is just relieving the pressure.
Going up, the pump applies pressure, apparently unevenly in your tractor's case. It is simply not right.
Keep griping to Kubota and go up the ladder until satisfaction is gained. Request a factory service representative to come out and look at your tractor's hydraulic functioning. For some reason, your dealer seems to be dropping the ball.
Back to the "going up and going down" factor. Try tightening the 3 PH lowering speed knob that is under the operator's seat. Then try loosening it. Try several positions.
Maybe the valve is somehow malfunctioning and causing the problem. Can't hurt to try something else to eliminate a possibility.
ryegrass26
United States
I've enjoyed most of the Kubota Tractors I've owned however the dealer in my area has very poor service. I had a similar issue with another tractor and ended up having to trade it with less than 50 hours because they treated me the same way. Later it turned out the poor fellow they ended up selling my tractor to unfortunately realized what I was trying to tell them was in fact a issue after the engine failed with less than 100 hours. I was told today that Kubota pulled the construction equipment line from them, so that leads me to believe I'm not the only customer unhappy with them.
I feel as though I didn't have to convince them to take my money and I'm not going to twist their arm to correct it. I actually called Kubota customer service and explained them my situation. Their first solution was to bring it to another dealer for repairs. When I refused to do so they said it was understandable and would get with the selling dealer to come up with a solution to get it repaired. I've given them over a week and I still haven't heard back from them. It's spring where I'm from and if I could do without a tractor I wouldn't have bought one...
With that being said I ordered me a very pricey but loaded up John Deere 5085M today. Hopefully I get what I bargained for this time!
I've decided to let an attorney deal with Kubota..
I appreciate the advice!!
GWD
Jan 8, 2010
792
19
Northern California
Sorry it had to get to this point. Poor customer service is certainly not a common Kubota problem in my experience.
