I am new to this sight and can use a little help
Several of the rollers in the injector pump froze up and destroyed the cam am housing..
We purchased a used Housing and governor,. Appears the same but assuming was off of a different piece of equipment since we have to make major addustments in the governor to get it set up the same as the old one.
the replacement pump we received appears different but dimensionally it fits, so assuming it from/for a different application as well.
We put it all together and after a little ^*&*^$&^ IT RUNS but not very well. on start billows blue white smoke, not throttle response, or power. Once it warms up the smoke lessons and all symptoms become better..
I believe Our issue is the shimming of the Pump to the Housing.. we started with the same # of shims and have increased them until we got it to run.
at this point i am unsure if we received compatible components and looking for help
