We reattached the backhoe (BT1400) after using a three point hitch implement on our M62, and have almost no swing power left or right.
Things get a bit better at high rpm’s - the hoe at least slowly swings, but it has no power. The controls work correctly. Everything else is good.
I was pretty careful during the detachment and reattachment to keep everything clean and reattach the hoses correctly. I’ve detached and reattached the hoe and it doesn’t solve the problem. I cycled it a bunch of times to see if there might be an air bubble in the control valve that could be moved - no improvement. I was really careful with the diverter valves.
This backhoe has 3 hoses – one hose is labeled “swing” – the connections are kind of idiot proof and can’t be connected incorrectly. They’re also color coded.
This is a new machine (yes, I called the dealer).
Anyone have any thoughts?
Thanks in advance for any help.
