Kubota M 8200 pto clutch
dusan
20
I have a 1999 kubota M 8200 and pto clutch is slipping . Pressure gauge is reading 400 psi, it will turn the pto but there is no power. Do you have to split it apart to install PTO clutch on tractor or can you do it from the rear? Thank you....
8,525
The PTO clutch pack is in the center of the transmission, so yes you would need to split the tractor in two in order to replace the clutch.
dusan
20
Thank you. That's what I have found out reading manual.
After splitting the tractor and rebuilding the pto clutch and controler the pto won't shut off. Need to check the correct pressure on controler? Thanks
dusan
20
