My Kubota L4701HST will run fine for about 15-30 minutes, full throttle, then will suddenly act as if under a great load and stall out. Will not recrank for 15-30 minutes. Then cranks and runs fine for a little while. Thermostat gauge not showing hot, but seems to take a long time to start moving up - It could be a bad gauge and is simply hot and not showing accurately. I also have been unable to get the DPF to regenerate. Has worked fine until lately. DPF warning lights are on , have tried to force it to run in Park, but no luck, will not ever clear when I run in full throttle. Run/-Min light goes off so it is getting enough RPM. I bought a new thermostat to install, but am now concerned that it is nothing to do with thermostat. My guess is it is the DPF possibly? Thermostat or gauge and thermostat both bad - Other thoughts? Also I have seen several posts on other sites regarding DPF deletion processes, but none that seem to work for Kubota. Anyone been able to make that work? Thanks for any assistance. PS - I would take to dealer but they are so backed up, would lose my tractor for a month or more while it sits waiting for its turn to get fixed.
