I just purchased L35, I believe it to be 2002. Its been around 0 deg f here, its warmed up to 20 deg F and this is my first GST transmission. Ive been reading alot about them before and since purchase. Today after a good warm up the shuttle reverse worked pretty quick. However the gear selector was still very slow. example running in 3rd in snow, shift to 4rth , tractor continues for about 1-2 seconds then you fill a crisp clean disconnect the tractor then slows for about 3 seconds then you fill the re-engament but the tractor has slowed down so then it loads engine then goes. I tried it higher gears and seemed same. next test. It seems to be connected solid with the engine once its engaged.
I dont know much about this tractor so Im making a list of what I want to do the tractor over the next two weeks, but Would like suggestions from other Orange owners.
