Kubota L275
JasonW
789
545
Al
Kubota L275 27HP 2wd
8x7 transmission
Dual clutch
Hour meter/tach does not work
Needs TLC but runs and drives
New front and rear tires on right side.
Have several hundred dollars worth of parts to go with it or I will replace them when/if I have time.
PTO will not disengage with clutch but will shift in and out. I would assume it needs a clutch as it’s a dual stage clutch. I’m able to replace if/when I have time if the buyer requests but the price will be higher.
I wouldn’t recommend using a bush hog with its current issue but something like a spreader would be fine.
Can include a 5’ bush hog
$3,000
Located in south Alabama.
