KUBOTA L245DT Help with Pricing
Spelunk73
Kubota L245DT
Jun 13, 2012
Indianapolis, IN
I have a Kubota L245Dt that i am going to list to sell and was wanting some help to determin its value. Here are the specifics of the machine. I have made all repairs that this machine needed just to get it ready to sell so that whoever purchases this tractor will have no worries for quit some time.
Tractor has 1317 hr on machine
Front Loader
2 New front Tires
New seals in all Lift and Bucket cylinders
New Battery and all new battery cables
New Tachometer cable
Replaced Bearing and seal in left rear axle
New seat
Changed oil and Filter
Drained and replaced Hydro trans fluid
Rear Tire are in decent shape some cracks but hold Air fine
No leaks of any kind on engine or anywhere else
PTO and 3 point hitch work fine
4 wheel drive works fine
Breaks Work Fine
Outer coverings on Hydraulic hoses show wear but no leaks
Paint is not in the greatest of shape, some rust on fenders and hood ( no Holes)
Surface rust on bucket and loader frame
Serial # on block is L245DT 52290 ( also help with what year this machine is would be great) I know its one of the earlier years, just not sure which one.
Thanks in advance for your help. I was hoping to get around $4,500.00
Bluegill
Jan 11, 2012
1,559
Success Missouri
Nice old tractor. I had one like it that was a 1980, 2wd, no loader. I believe the L245 was made from the late 70s' to mid 80s'?
$4500 seems doable, but likely the upper end. If the loader was sand blasted and painted it'd sure look nicer.
BTW, if mine had been 4wd, I'd have never got rid of it.
MagKarl
L245DT
Aug 2, 2010
663
Olympia, WA
I have the same machine. I sure hope you can get more. You'd get $5-6000 easy around here. I paid $5800 for mine with a 5 foot brush mower and thought I'd done well. I was ready to spend that on a Yanmar as those are cheaper than Kubotas around here.
South
L245DT
Feb 22, 2011
50
ohio
Im with MagKarl...gave 5800 for my L245DT almost 2 years ago, 680 hrs, FEL, front forks attachment, and a carryall.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
11
Richmond Va
I want to upgrade my lil B6100 to something like that L245 some kinda bad and no $4,500 to $6,000 isnt a bad price tag
