I've got a Kubota L2250. One of the lift arms is leaking out the side where the splined shaft comes out of the housing.
Does the whole housing have to be removed to replace the seals on the shaft or can it just be knocked out the side of the housing?
If the whole thing does have to be removed is there anything else I should check while I'm in there?
Thank you
Thank you
