Kubota L2201D
Rod1995
sudbury, ontario canada
Can someone please help with this? Tks so much.....
What hydraulic/trans fluid I'd to be used? Can't seem to get a clear answer.
What engine oil recommended?
Lastly, anyone have/know of availability of manual?
2,559
I think you have a gray market tractor and will have to figure out what model it is similar to and get that manual at Kubota books dot com
For the fluid, I assume it is a manual gear drive transmission so you can use universal tractor transmission/hydraulic fluid like Kubota UDT or this
At the time the tractor was manufactured the manual would probably recommend 80 wt gear oil since that was all there was available
2,923
I would recommend UDT or as mentioned any hydraulic fluid should be fine.
Another post about the L2201 and oils:
https://www.orangetractortalks.com/forums/threads/l2201-trnsmission-fluid.34912/
AS for engine oil - I would use 10w30 or even 5w-30 if you can get, the latter simply for the cold weather start up.
AS for a model that is very close to your L2201, the L245 used the same engine.
Thunder Fish
ZL2202DT-M
Oct 21, 2017
158
100 Mile House BC,Canada
I'm running a ZL2202DT,using UTD or equivalent in the drive box and 10W-30 diesel in the engine,there is a bunch of Japanese under the hood that I scanned with my smart phone using Google translate
Roadworthy
L2501 HST
Aug 17, 2019
1,647
529
Benton City, WA
I don't know where you're located but older tractors generally used a 15W-40 oil, diesel rated of course. You could go with 5W-50 for easier starts in cold weather. I live in Washington state and 15W-40 starts easily enough here even with a tractor kept outdoors in a shed.
