Hi All,
I own a Kubota GL32 and the clutch pedal seams ok when you depress it however the PTO grinds when you try to engage gears...Gear 1 on the PTO engages after little grinding but the other grinds a bit more that I do not keep on trying.
Also the movement gears from 1 to 8 change ok without grinding even if clutch seams not to be working.
When going up a hill or ramp if you depress the clutch pedal it seams like clutch is not working because with clutch pedal depressed the tractor keeps on moving forward.
Any idea what might be the issuse?
Thanks in advance.
Thanks in advance.
