I HAVE A KUBOTA ENGINE/ ELECTRICAL GENERATOR THAT HAS DEVELOPED A ISSUE OF NOT HOLDING A LOAD WITH THE VOLTAGE AND RPM SAGING I REPLACED THE ELECTRICAL END. AND RAN IT FOR 3 HOURS IT SEEM TO WORK OK. THEN STATED SAGING AGAIN. 1) I HAVE REPLACED THE FUEL FILTERS AND PUMP. 2) REMOVED THE INJECTION PUMP TO INSPECTED IT AND THE RACK IS FREE. 3) ALL THE PIECES SEEM TO BE IN PLACE WITH THE GOVERNOR THE RACK SLIDE, AND SPRING 4) I HAVE NOT OPENED THE SIDE COVER TO EXAMINE THE GOVERNOR NOR HAVE I TRIED TO ADJ THE GOVERNOR. ANY ADVICE WOULD BE VERY HELPFUL . I MIGHT ADD THE GOVERNOR IS SET TO RUN AT 1800RPM. IT STARTS AND RUNS AT 1800 NO LOAD.
