Kubota BX2660 tail lights
AshleyBS55
L245DT 4WD
Sep 30, 2013
86
Palestine, WV, US
All the lights on my Kubota BX2660 work except for the tail lights. My turn signal/warning lights and headlights are fine. Is there an inline fuse somewhere I might check or could it be something else?
Thanks,
Bruce
2,833
Thanks,
Bruce
Should be a fuse for that - 20 amp if my memory serves me correct. Under the bonnet/hood. Lower left fuse should be labeled "working lights" .....whatever that means!
SDMauler
2009 BX2360TV60, RCK60B-23BX
Aug 8, 2014
82
Parker, SD
Also check the wiring harness right behind the tail lights. There are some bullet connectors under there that tend to get dirty or corroded. Mine quit every so often, I give them a twist, and they start working again.
Grouse Feathers
Feb 16, 2015
1,022
11
Lovells, Mi
Any chance they are burned out? The tail lights on my BX2370 both burned out. I leave my lights on all the time so the LCD dash display is always visible. And I have the head lights unplugged as they were a nuisance when blowing snow at night (the LED flood lights, cab mounted, are much better). To replace the tail lights I went to an auto parts store and bought an LED replacement bulb.
