Kubota BX - Can You USE 4WD with "rabbit" (fast ) Setting ?
TheKubotaKing
Kubota BX2380, with standard front loader, and LandPride rear blade ( 60 inch )
Nov 2, 2020
58
9
United States
Hi everyone !
Hopefully a good question here........
IF you are in 4WD while doing snow clearing on a gravel driveway, is it OK to be using the faster speed ( rabbit icon ) setting on the transmission ? ... or is this big BIG NO-NO ? .... I did look at the Kubota manual yesterday and there's no mention of it that I found, so thought I should ask here.
Thanks for any info as usual ! and I appreciate all answers and your time ! :)
5,940
Yep. you're fine in high range as long as you have the power.
I did it all the time with my old machine.
armylifer
Mar 26, 2013
2,225
982
Thurston County, WA
The short answer is yes. The long answer depends on conditions. You will not hurt the drive train by using 4wd in high range.
TheKubotaKing
Nov 2, 2020
58
9
United States
Hello to both of you ! Thanks very much for that info ! - it's much appreciated. :) :)
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,820
2,231
Near Lancaster, PA, USA
I would put it in 2WD if there is sufficient traction just to decrease stress on the driveline. When I go out on the roads for any distance in snow I use 2WD when possible. There are some hills and the tractor climbs them a little easier when not in 4WD. I attribute that to power being wasted on driveline binding.
Kurtee
BX2660, BX2680 cab, JD 2032R, Honda 5518, JD X590, JD X739
Oct 3, 2013
319
107
Nicollet, mn
Use hi range at will. I use hi must of the time when pushing snow. I have had all 4 wheels spinning as fast as they will go on snow and ice pushing or trying to push snow.
