I want to tune up the loader spool valve control so the lever is quite so sloppy so I can make it through the season when I can take it offline to service the spool valve detents. I'm referring to the lever assembly (70726-61175) connecting via pins, links (70726-61210), and connectors (70764-61190) to the valve spools. I'm assuming that I'll have to use bushings/sleeves and mill or replace the pins which I'm capable enough to manage. Since these parts are no longer available, I'm going to give it a shot before dumping a bunch of time and $$$ into a replacement valve. Any help would be appreciated.
