I have a 2011 Kubota B3200 with the hydrostat transmission. The Kubota runs great but the hst transmission slips under a load. The problem seems to get worse as the fluid gets warmer. The High range is unusable unless you are going down hill. Once it’s warm up, in low range, u can try to push some snow to a pile and the wheels won’t even spin on ice. You can hear it whine and I Even try having the pedal half way down and it still doesn’t help. I verified the clutch pedal isn’t too tight and when it is slipping/wineing I can push the clutch down and it does release which leads me back to the HST. The fluid doesn’t look burnt or dirty and I did check the screen which it is clean with no shaving or blockage. I have changed the fluid and filter with Kubota items but still the same. Machine has 1074 hours on it. Any direction would be helpful before I have to drop this off at the dealer to have it looked at.
