Kubota B1700 (D905) thrust lever
Nunner
Kubota B1700
Mar 22, 2021
Bradford
Here my story. I have a d905. No fuel coming up to the injectors. Toke it to the dealer. They said it's the thrust lever. It's broking. They said it's very hard to fix. Does anyone have something good to say. I really love my tractor.
11,559
If the thrust lever is broken it's not that hard of a fix, any competent mechanic can change it in a fairly short time.
You probably wouldn't just change just the lever, you would change the whole assembly.
It's a fairly cheap part at 165 new.
11,559
Probably a couple hours at most, the thrust plate is held to the governor linkage assembly by rivets.
This is why it's easier to replace the assembly, which is held into the engine by a couple bolts and a pin.
If you want to do it yourself get the WSM (aka service manual) to walk you through removing and replacing it.
You can get the WSM for free off of Kubotabooks.com
Nunner
Kubota B1700
Mar 22, 2021
Bradford
I am still waiting. They have taken the the arm to a machine shop to change the rivets. That's what they said anyways.
