kubota 2110 mower
thomas57
kubota motor d782 3cyl mower
Apr 20, 2021
florida
how to adj the idle on my kubota 2110 die. ( D 782 engine ) after idle the thing runs very good // there is a little PING \ raddle noise some were in the motor ?
I did replace the INJECTORS and glow plugs because it had 1200 + hours on it .
5,469
2,164
I'll say it again, but typically pumps and injectors don't ever need to be replaced on Kubota mechanical injected engines UNLESS poor or wrong fuel is run through them. But people do it anyway because they want to be diesel mechanics like those movie stars on the youtube or tv.
But since you've already done that, I assume the injection timing is right. There ain't no adjusting the idle speed. They're wired in position from the factory. Actually the factory doesn't even give out the slow and fast idle speed specs on them, "adjusting" the stops also affects emissions so they tell everyone to leave them alone for that reason alone.
diesels rattle a little anyway but if it's an "odd" rattle, you may have internal engine problems of which aren't able to be diagnosed with any sort of precision without being there to see it in person.
whitetiger
Nov 20, 2011
3,186
1,604
Kansas City, KS
Low Idle: 900-1000 RPMs High Idle: 3450 RPMs, published in the Kubota Work Shop Manual.
