Kuboda Battery Type?
backriver
9
Waterville, ME
I have a Kuboda L 3560 and would like to trickle charge the battery. The charger wants you to select either a Lithium or(LiFePO4) or Lead Acid battery to charge.
Which mode should I use.
Thanks,
Bert
SidecarFlip
Banned
562
Lead acid. I doubt you have a Lithium battery. If you do, you have way more money than I do. Lithium batteries of the size that are required to start an engine are upwards of a thousand bucks.
SidecarFlip
Banned
562
I like that "Lifetime Warranty."
Might be just the thing for a tractor collector with a dozen or more restored tractors in the barn.
SDT
12 volt, 100 amp hour = $1249.00. You can buy a bunch of conventional flooded cell jars for that.......:eek:
Those are the hot item for RV's today until people find out the cost that is. My RV has a bank of conventional flooded cell batteries, I'm fine with that.
200mph
Mar 3, 2017
1,228
65
PA
Maybe when they start to repurpose the batteries used in electrical cars the price will drop. (ie: to maintain range)
There has been talk about using initial battery life in cars/trucks and then repurposing them in less critical applications as the battery capacity decreases with age. Maybe the RV market will benefit from this at some point.
SidecarFlip
Banned
562
Don't know. I don't care much for them anyway. Even takes a special charger to charge them up. Only good thing is, no external venting and can be used upside down.
