Kodiak Bush Hog Rotary Cutter Bolt Size? Anyone know?
LDowney
Kubota MX6000
Hey guys. I have a fairly new Kodiak 6 ft. Rotary Cutter and I need to remove the blades. It has a large bolt that needs to be removed. It's larger than my largest 1 1/2 inch socket. Does anyone know the exact size of this nut? And does Tractor Supply sell a socket to fit it? Lowes does not. The largest they sell is 1 1/2 inch.
Thanks.
Technical Ted
L3560/cab LA805 loader LandPride RCF2060 rotary cutter, HLA hyd angle snow blade
Jul 2, 2016
105
Dansville NY
If all else fails and no one replies, can you get in there to measure it with a set of calipers or something? Or maybe use an adjustable wrench to fit the nut then measure the opening on the wrench. I've used that method before as well, before I had calipers.
Just food for thought,
Ted
