key will not turn off tractor help
msgt1942
kubota b2150
Oct 27, 2013
20
kingman az usa
I just bought a Kubota I think it is a b2150dt I don't understand the hsd hst and stuff and I don't know the year the previous owner did not know either. the problem also is that when I turn the tractor off it wont I have to pull a fuel knob lever then it shuts off. the tractor will without starting it just turning the key to the on position and then off make a cliking sound after a few seconds so im assuming some relay or thingy is working to try and shut it off but it wont any help or advice.
GWD
M7040, L48 TLB, BX2200
Jan 8, 2010
792
17
Northern California
Very common problem.
The fuel shut off solenoid is malfunctioning.
(At least that is what I can decipher from your post.)
mendonsy
B7500HST/LA302
May 28, 2012
357
34
Mendon, NY
Does the B2150 have a shutoff solenoid?? My B7500 doesn't have one, only the manual shutoff. Turning off the key has no effect .
Grahamguy
Kubota BX25, Land pride post hole didgger.
Jun 26, 2013
Graham, WA. USA
There should be a small red knob on the right hand side. If you pull it out it should shut the tractor off.
msgt1942
kubota b2150
Oct 27, 2013
20
kingman az usa
hey guys first off all thanks for your replies I went and looked (played) with my new (actually its old) b2150. and I saw were the knob rod went and how it worked and noticed linkage assembly to a solenoid with an arm and it did not operate/work that's why im having to do it manually so I guess all you guys are right!!!! sooo now were can I find this part and is it expensive? thanks again. first tractor so all the handles are a bit intimidating but I did run it and seemed good the tractor does not sit level so the bucket l350 looks even more crooked then it is but no adjustments that I can see its 1 inch leaning to the left?
8,766
As far as the bucket alignment #1 check tire pressure first!
I'll get you the part # in the morning.;)
GWD
Jan 8, 2010
792
17
Northern California
Put your tractor model in an eBay search. Many related items will show up. Maybe a stop solenoid will be one of them.
